Hi Jose,
You know,I just have a datasheet of the MWCT10x3A,I come true the following source codes by myself,but I have no hardware to check it. So now I have to carefully write this SPI function, and could you help me to check these codes ?
#if 1//20190315 just for test SPI function
#define SPI_POLLING_TRIALS 0xFFF0U
//SPI init
unsigned char spi_init(void)
//0.SIM_PCE1 (bit9: QSPI0 peripheral clok enable)
//SIM_PCE1 &= ~SIM_PCE1_QSPI1;//QSPI1 IPBus Clock Disnable (NXP mcu no this SPI1?)
SIM_PCE1 |= SIM_PCE1_QSPI0;//QSPI0 IPBus Clock Enable
//1.SIM_GPSCL SIM_GPSCH (GPIOC peripheral select)
SIM_GPSCL &= ~SIM_GPSCL_C7;//ss0_b
SIM_GPSCH &= ~SIM_GPSCH_C8;//miso0
SIM_GPSCH &= ~SIM_GPSCH_C9;//sclk0
SIM_GPSCH &= ~SIM_GPSCH_C10;//mosi0
//2.(0X0780)GPIO config :GPIOC_PUR(1 weak internal pull for output function;0 no pull) GPIOC_DR(no usefull) GPIOC_DDR(0 input; 1 output) GPIOC_PER(0: GPIO function; 1:peripheral function)
//GPIOC_PUR;//must config?
//GPIOC_DR;//must config?
//GPIOC_DDR;//must config?
GPIOC_PER |= GPIOC_PER_PE_7|GPIOC_PER_PE_8|GPIOC_PER_PE_9|GPIOC_PER_PE_10;//0X0780: BIT7 - C7(SS0)/ BIT8 - C8(MISO0)/ BIT9 - C9(SCLK0)/ BIT10 - C10(MOSI0)
//3.QSPI0_SPSCR QSPI0_SPDSR QSPI0_SPDRR QSPI0_SPDTR QSPI0_SPFIFO QSPI0_SPWAIT QSPI0_SPCTL2 (clk interrupt master)
//mode: master
QSPI0_SPSCR |= QSPI0_SPSCR_SPMSTR;//master mode
//starts transaction: Rising edge of SCLK
QSPI0_SPSCR &= ~QSPI0_SPSCR_CPOL;//Rising edge of SCLK starts transaction
//transmitted: MSBfirst
QSPI0_SPSCR &= ~QSPI0_SPSCR_DSO;//MSB transmitted first
//Transmit interrupt: enable
QSPI0_SPSCR |= QSPI0_SPSCR_SPTIE;//Transmit interrupt enable
//Receiver interrupt: enable
QSPI0_SPSCR |= QSPI0_SPSCR_SPRIE;//Receiver Interrupt Enable
//spi pin : pull
QSPI0_SPDSR &= ~QSPI0_SPDSR_WOM;//spi pin (0: pull 1:no pull)
//QSPI0_SPDSR |= 0x4000;//spi transmit DMA enable
//QSPI0_SPDSR |= 0x2000;//spi receive DMA enable
QSPI0_SPDSR &= ~QSPI0_SPDSR_SSB_ODM;//spi ss_b (0: pull 1: open drain)
QSPI0_SPDSR |= QSPI0_SPDSR_SSB_AUTO;//spi ss_b (0: ss_b out by software; 1: ss_b out by hardware)
//transaction data size = 8 bits
QSPI0_SPDSR |= QSPI0_SPDSR_DS_0;
QSPI0_SPDSR |= QSPI0_SPDSR_DS_1;
QSPI0_SPDSR |= QSPI0_SPDSR_DS_2;//DS0_0|DS0_1|DS0_2 = 7 : 8 bits transaction data size ???
//Baud rate = clk/16
QSPI0_SPSCR |= QSPI0_SPSCR_SPR_0;
QSPI0_SPSCR |= QSPI0_SPSCR_SPR_1;
QSPI0_SPSCR &= ~QSPI0_SPSCR_SPR_2;//011 BD = 16;Baud rate = clk/BD SPR3 = 0;
QSPI0_SPDSR &= ~QSPI0_SPDSR_SPR3;//011 BD = 16;Baud rate = clk/BD SPR3 = 0;
//QSPI0_SPFIFO;//SPI FIFO; -- dont use SPI FIFO,ok?
//QSPI0_SPWAIT;//Transmit Wait Delay; -- what function?
//QSPI0_SPCTL2;//Stop Mode Holdoff Enable; -- what function?(MCU into halt mode,SPI enable?disable?)
//SPI mode = enable
QSPI0_SPSCR |= QSPI0_SPSCR_SPE;//enable SPI mode
return TRUE;
//SPI data send
unsigned char spi_send_block(unsigned char *pBlock, unsigned int wLen)
unsigned char send_ret = FALSE;
uint16 send_Tr = 0;
for(send_Tr = 0U; send_Tr < SPI_POLLING_TRIALS; send_Tr++)
if(QSPI0_SPSCR & QSPI0_SPSCR_SPTE)//1: empty
if(wLen != 0U)
wLen--; //Decrese number of chars for the transmit
QSPI0_SPDTR = *pBlock++;//QSPI0_SPDTR;//Data Transmit Register write_only
else
send_ret = TRUE;//Finished data sent
return send_ret;
//SPI data receive
unsigned char spi_recv_block(unsigned char *pBlock, unsigned int wLen)
unsigned char recv_ret = FALSE;
uint16 recv_Tr = 0;
for(recv_Tr = 0U; recv_Tr < SPI_POLLING_TRIALS; recv_Tr++)
if(QSPI0_SPSCR & QSPI0_SPSCR_SPRF)//1: receive full
wLen--;
if(wLen != 0U)
*pBlock++ = (unsigned char) QSPI0_SPDRR;//QSPI0_SPDRR;//Data Receive Register read_only
else
recv_ret = TRUE;//Finished data receive
break;
return recv_ret;
#endif
