MPC5603B In-System Programming Specifications
778 次查看
andreacompagni
Hello everyone,
I need to program the MPC5603B microcontroller, where can I find the in-system programming specifications?
Thanks in advance
Kind Regards
标记 (2)
621 次查看
martin_kovar
could you please more specify your requirement?
Please check the link below. There are the most useful documents you need.
MPC560xB|32-bit MCU|Body-Electronic|NXP
There is also EABI document, which can be useful
http://cache.nxp.com/docs/en/application-note/PPCEABI.pdf?fsrch=1&sr=2&pageNum=1
and instruction set documents
http://cache.nxp.com/docs/en/reference-manual/VLEPEM.pdf?fsrch=1&sr=1&pageNum=1
https://www.nxp.com/webapp/Download?colCode=EREF_RM&location=null&fsrch=1&sr=2&pageNum=1&Parent_node...
Martin
621 次查看
andreacompagni
thank you for your reply.
I'll specify my question: I'm an Application Designer in Lynxar Technologies (www.lynxartech.com), a leader company in the field of In-System Programming, and a Customer asked us to support the NXP MPC56xx Family. So I need the documentation about the in-system progamming protocol and the flash programming procedure to implement the algorithms on our programmer.
I'll check the documentation you linked, if would need something more, I'll let you know.
Thank you again for the support
Sincerly
Andrea
