I'm developing a new system using this high power amplifier,MMA25312BT1 , and i 'd need its 50 OHM applicattion circuit at 2400 MHZ. Could I get the MMA25312BT1 Test Circuit Component Designations and Values at 2400 MHZ?
Thanks in advanced.
How can I create a technical support ticket?
Thanks.
Please, create a technical support ticket to get DXF and Gerber files for the MMA25312BT1 test board.
The BOM and component placements are provided in datasheet. The circuit can be used at 2400MHz.
Pavel
TIC
