MC13224V Interrupt
MC13224V Interrupt
1,030件の閲覧回数
Epopeia
I'm using MC13224V, and need to connect a detector zero-cross. This integrated circuit has no external interrupt. What should I do? I connect the keyboard (KBI)?
Thank you.
Francesco
タグ(1)
2 返答(返信)
441件の閲覧回数
redbee
Thank you.
Francesco
KBI4-7 can be used to generate interrupts from external sources. I have some code in Contiki that does this. See http://mc1322x.devl.org for more details.
The ADCs can also be programmed to auto-run and generate interrupts at specific levels.
You can probably use the TMR modules for what you want too.
-Mar.
441件の閲覧回数
Epopeia
Mar,
Thank you.
