LCD segment was not turn off fully (using PCF85134)
Vamsi091
When I turn off the LCD Segments I can Still see a little light in the Segment
I was using PCF85134 LCD Segment driver
Any sample code will be great help.
Best Reagrds,
Vamsi
Tags (2)
JozefKozon
Dear Vasmi,
I apologize for a late reply.
I would need some values from you. Please provide the following values.
Vth(on) or Vsat=
Vth(off)=
VLCD=
Also please state what LCD drive mode you are using as described in the Table 5. in the PCF85134 datasheet.
To update this case, you may reply by email, otherwise it will be automatically closed in seven days.
With Best Regards,
Jozef
