Freertos defines whether the software timer consumes heap or stack resources?
547 次查看
918338431
Does freertos define a software timer, does the system consume heap or stack resources?
What is the upper limit?
【PCB Prototype】,China PCB Prototype, PCB Prototyping, Fabrication Manufacturer - PCBIndex.com
500 次查看
danielchen
Hi Julian:
YES, Freertos defined a software timer, it needs RAM. The RAM can be automatically dynamically allocated from the RTOS heap within the RTOS API object creation functions, or it can can be provided by the application writer
Please refer to below link, I hope it helps
Tutorial: Understanding and Using FreeRTOS Software Timers | MCU on Eclipse
