Does SJA11XX support vlan config and control forwarding?
373件の閲覧回数
yangjinzhuang
       I am looking for a switch chip that can configure vlans and configure some VLAN data streams to be discarded, some VLAN data streams to be sent to the CPU, and some VLAN data streams to be forwarded。
      I am not sure SJA1100 support config vlan 1-4095, and config some vlan datastream  dropping  and some vlan datastream sending to CPU.
5 返答(返信)
347件の閲覧回数
lukaszadrapa
Hi @yangjinzhuang
please take a look at this application note which explains these features in detail:
https://www.nxp.com/webapp/sd/collateral/1660325208093731308575?version=1.0
Lukas
273件の閲覧回数
yangjinzhuang
       I can't open  https://www.nxp.com/webapp/sd/collateral/1660325208093731308575?version=1.0
      the page not find
269件の閲覧回数
lukaszadrapa
Try to open SJA1110 page:
https://www.nxp.com/products/interfaces/ethernet-/automotive-ethernet-switches/multi-gig-safe-and-se...
Then got to the Documentation -> Secure Files.
Here search for "AN12925 SJA1110 software application notes", document number AH641610.
If you can't see it here, you probably don't have access to this document. In this case, please follow instructions on the pages below and ask for higher access rights:
https://www.nxp.com/support/support/secure-access-rights:SEC-ACCESS
https://www.nxp.com/support/support/secure-access-rights/secure-access-rights-faqs:SEC-ACCESS-FAQS
Lukas
369件の閲覧回数
yangjinzhuang
       What configuration features does SJA1100 support?
       What configuration features are supported for forwarding control?
365件の閲覧回数
yangjinzhuang
        Does SJA1110 support config drop vlan stream
