I am looking for a switch chip that can configure vlans and configure some VLAN data streams to be discarded, some VLAN data streams to be sent to the CPU, and some VLAN data streams to be forwarded。
I am not sure SJA1100 support config vlan 1-4095, and config some vlan datastream dropping and some vlan datastream sending to CPU.
please take a look at this application note which explains these features in detail:
https://www.nxp.com/webapp/sd/collateral/1660325208093731308575?version=1.0
Lukas
I can't open https://www.nxp.com/webapp/sd/collateral/1660325208093731308575?version=1.0
the page not find
Try to open SJA1110 page:
Then got to the Documentation -> Secure Files.
Here search for "AN12925 SJA1110 software application notes", document number AH641610.
If you can't see it here, you probably don't have access to this document. In this case, please follow instructions on the pages below and ask for higher access rights:
https://www.nxp.com/support/support/secure-access-rights:SEC-ACCESS
https://www.nxp.com/support/support/secure-access-rights/secure-access-rights-faqs:SEC-ACCESS-FAQS
Lukas
What configuration features does SJA1100 support?
What configuration features are supported for forwarding control?
Does SJA1110 support config drop vlan stream
