I was trying to implement SPI on NCB of MC13224. When I flashed the code and observed the lines on CRO, I found that it is giving proper clock and chip select on lines but the data I was sending over MOSI and expecting it over MISO was not there [the line was not showing any reading et all]. At start I found these lines were shared with LCD so I disabled LCD, still MOSI and MISO are not working. Is there anything I missed while coding?
Solved! Go to Solution.
