Developing a DRM of AM radio (DRM 30) based on NXP DiRaNa 3 (SAF775x) and SAF360X modules.
It is understood that, the internal flash memory of host processor can be used to boot program code of DiRaNa 3 (No dedicated flash memory required for SAF775X).
For digital radio processor SAF360X required a dedicated flash memory interface over SPI?
Thank you.
Gopal
Hi Gopala,
Tuner devices like the SAF360x are made for a small part of the industry, therefore information, documentation and support is very limited.
Unfortunately, I was not able to get the requested information, this request need to comes directly from your NXP DBM (Anju is your direct contact in NXP) or Distributor FAE representative, so you should contact your NXP DBM or FAE directly to get access to the requested information.
I apologize for the problems this may cause.
Please see below a link to a list of our authorized distributors.
Distributor Network | NXP Semiconductors
With Best Regards,
Jozef
