Ask questions about P3A9606JK IBIS Model
361 次查看
HDB3i
Hello
I found some problems when I made the P3A9606 IBIS model for I3C signal simulation, and I would like to ask you about them.
1. I wonder why A port and B port have any connection before. When I3C signal is input from B port and output from A port, does the signal simulation need to add the IBIS model of A&B Port at the same time? Because I found that the simulation results of both adding A&B port model and only adding A port model were consistent.
2. In my simulation results, the output of A port does not meet the voltage requirements. Can you share your simulation examples and simulation results?
thanks
have a nice day!
339 次查看
guoweisun
You can download the IBIS model from below link:
Search | NXP Semiconductors
