About the problem that MC9S12ZVL chip cannot detect LIN bus bit error
pan_wen
        We use the CANoe script function linInvertRespBit (xx, xx, xx, xx) to interfere with the stop bits of each byte in the LIN frame data field.Failure of the third, fourth, fifth and eighth bytes cannot be detected by the chip;Other bytes can.
linInvertRespBit()  function
danielmartynek
Hello Simon,
Do you use LIN2.x and SAE J2602 Stack.
If so, which version?
BR, Daniel
