56800E - Fractional cos problem
2,195 次查看
admin
Specialist II
I use "tfr16CosPIx" function from CW for 56800E. There is problem when i try to calculate cos of falues near zero. Result of fuction jump from -1 to 1 some times when input values changed from -20 ... +20 (approx.).
Anybody can help me?
Message Edited by Alban on 2006-08-31 05:53 PM
标记 (2)
1,266 次查看
admin
Specialist II
I found that the problem is in the saturation. CPU's property "Saturation mode" doesn't help. I use this function together with svmStd function (from SpaceVectorMod bean) where saturation off - SA bit of OMR register is cleared. So if you have the same problem set this bit manually.
1,267 次查看
admin
Specialist II
