30x50mm antenna with matching components in OM27462CDKP Development Kit
Andrew93
Hi, NXP
I am looking for  design files of 30x50mm antenna with matching components in OM27462CDKP Development Kit.  I couldn't find it ay all.
And I want to buy a spare of this antenna board. Tell me how to do it.
Thanks.
Andrew
Labels (2)
KellyLi
Hello @Andrew93
It's recommended that you can use the NFC antenna development kit (OM26630FDK), which is also compatible with PN7462 family. Please check the below link:
https://www.nxp.com/products/rfid-nfc/nfc-hf/nfc-readers/nfc-antenna-development-kit:OM29263ADK
kelly
Andrew93
Thank you for your response.
Unfortunately, the information you provided doesn't align with what I'm seeking. I'm actually searching for design files for a 30x50mm antenna along with its matching components.
Andrew
KellyLi
Hello @Andrew93
There is no design document for the antenna board you mentioned, indeed, sorry for that, but which actually consists of two parts: matching and antenna coil. So, I recommend OM29263ADK to you, it has design files, and also works with the PN7462.
Also, maybe the below document could be helpful to you, please refer to it.
https://www.nxp.com.cn/docs/en/user-guide/UM11098.pdf
kelly
