Intention - Isolation of Software Components (data) so that data sensitive to one component cannot be overwritten by another component (to achieve safety and data protection).
in C - In C, we could simply define pointers to specific memory location and pass these pointers to be updated by the Software Components.
The problem - I have is in Simulink, I don't know how to achieve this separation of memory. Ofcourse I understand that the code is generated from Simulink to C. But i cannot apply the above mentioned technique in Simulink where I can pass pointers (pointing to specific memory location) through the Software Components. What are the other ways I can manage data protection in Simulink such that the generated code is usable with very little modification. The little modification I can foresee is modifying the compiler/linker files. Also please note, I do understand that the SMPU shall be used but lets assume I know how to use the SMPU to configure the regions of memory.
Rephrasing the question - Assuming I have used the SMPU to configure the regions of memory and the appropriate rights. How can I protect data of the software components through Simulink?
Hi Raghu,
For some unknown issues we have overlook this thread. Due to the long delay - is it still an issue ?
Hi Dumitru,
We have managed to solve the issue but I would still like to hear your solution. Could you please elaborate.
