I'm trying to get I2C working on the S32K144 using Simulink Toolbox but there's no input for a register address. Can I edit the block to accept a register address in addition to the slave address? Simulink provides a block that has this capability, could I use that instead?
Solved! Go to Solution.
Hello sparkee,
Unfortunately you can't customize the block yourself, as the scripts that control the data (the data flow Simulink -> Simulink coder <tlc files>) are p-files and not m-files that are editable by you.
I understand your use-case and we'll take it under review for our next update on S32K toolbox that will most probably be live in Q3. I will try to push it as an update to this version (which would be quicker than Q3), but I cannot make any promises.
Kind regards,
Razvan.
Hello sparkee,
Kind regards,
Razvan.
Thank you constantinrazvan.chivu for your quick reply and prompt action. We will try to roll our own for now and hope that the update comes before we hit production.
Hello sparkee,
Can you let us know what is your timeframe? Maybe we can take that into account.
Kind regards,
Razvan.
We plan to be ready for production when we announce at our September conference.
Hello sparkee,
Thank you for this information. I will let you know soon if we can push it as an update earlier or if will be released with our new version in Q3.
Kind regards,
Razvan.
