Dear team,
After followed all installation guide including RSDK, I tried to run the example code, "demo_4antennas_video.m".
However, I've encountered error message below.
---Generate input data.
---Running Range FFT.
Not enough input arguments.
Error in rangeFFT (line 181) shft_val = shiftOutput; % Shift value - signed 6-bit number
Error in demo_4antennas_video (line 81)
output_rangeFFT_bitexact = rangeFFT(input_data_rs * 2^(NBITS-1), window_rangeFFT_rs * 2^(NBITS-1), twiddle_rangeFFT * 2^(NBITS-1), M, N, P);
Based on error msg, I guess we need to configure the input parameters correctly, especially for rangeFFT();
I'm using RSDK 0.9.0 beta version now.
Could you suggest the solution for this issue?
Thank you
Justin
Hello, Lulian
Thanks for your feedback.
Could verified it worked well with the updated script.
Thank you
Justin
