NTS0104 internal pull-up resistor, output voltage accuracy
815 次查看
akihiro_yamada
1. Please tell me the tolerance of 10kΩ internal pull-up resistor of B port.
2. If the current source of B port is only 10kΩ internal pull-up resistor, which does output voltage tolerance depend on VCC or 0.67VCCO?
标记 (2)
758 次查看
guoweisun
1:Tolerance is about +-20%
2: You can check datasheet page8 table9 for VOH/VOL specification.
758 次查看
akihiro_yamada
Dear G.w. Sun,
Thank you for your reply.
Problem solved.
