LX2160 TFTP enabled
LX2160 TFTP enabled
2,502件の閲覧回数
ranga_yn
with LSDK 19.09 SD boot I have 2 questions :
1. when the Ethernet is connected to the 1G MAC 17 and tried to setup the TFTP with the server - Ping is always failing.
   Is there any make changes /build changes which need to be made on LX2160 . TFTP on 2088 is working fine for US.
2. qixis_reset SD   is the resetting the Board and freezes on LX2160 . Any specific reason for this.
タグ(3)
2,402件の閲覧回数
yipingwang
Hello Ranganatha YN,
1. Please check whether MC firmware, DPC and DPL have been deployed in SD card.
                          SD start block no.      QSPI/XSPI
DPAA2-MC       0x05000                      0xa00000
DPAA2 DPL      0x06800                      0xd00000
DPAA2 DPC     0x07000                      0xe00000
MC firmware:
$ flex-builder -c mc_bin -m lx2160ardb
build/firmware/mc_bin/lx2160a/mc_10.18.0_lx2160a.itb
DPL and DPC:
$ flex-builder -c mc_utils -m lx2160ardb
build/firmware/mc_utils/config/lx2160a/RDB/
2. Have you deployed SD firmware image into SD card?
$ flex-builder -i mkfw -m lx2160ardb -b sd
   flexbuild_lsdk1909/build/images/firmware_lx2160ardb_uboot_sdboot.img
Please deploy the firmware at block 8 on SD card.
Yiping
