Remote Access Unit Block Diagram
Description
Industry 4.0 applications demand superior performance and reliable communications for network synchronization, on-time data delivery, and energy efficiency—even under the most extreme operating conditions. Current manufacturing challenges require flexible platforms capable of uniting trustworthy networking protocols with modern and reliable machine-to-machine communications.
A remote access unit works as an interface for machinery that can’t be accessed. This tool displays parameters, measurements and can control any features of the linked machine.
This remote access unit application is based in an i.MX 6 applications processor that can be programmed with a Linux distribution and Built-in 2G/3G/GPS/Glonass.
Features
  • GPU 3D
  • GPU 2D (Vector Graphics)
  • Camera Interface
  • Cryptographic cipher engines
  • Tamper detection
  • Ethernet
  • Four USB2.0
Block Diagram
Products
Category Name 1:
MPU
Product URL 1
i.MX 6Dual Applications Processors | Dual Arm® Cortex®-A9 @1.2GHz | NXP
Product Description 1
The i.MX 6 series of applications processors combines broad levels of integration and power-efficient processing capabilities all the way up to bleeding edge 3D and 2D graphics, as well as high-definition video, to provide a new level of multimedia performance for an unbounded next-generation user experience.
Category Name 2:
Transceiver
Product URL 1
TJA1057 | High speed CAN transceiver | NXP
The TJA1057 is part of the Mantis family of high-speed CAN transceivers. It provides an interface between a Controller Area Network (CAN) protocol controller and the physical two-wire CAN bus
Product URL 2
TJA1101 | 2nd generation PHY Transceiver | NXP
Product Description 2
TJA1101 is a high-performance single port, IEEE 100BASE-T1 compliant Ethernet PHY Transceiver.
Product URL 3
Logic controlled high-side power switch | NXP
Product Description
The NX5P1100 is an advanced power switch and ESD-protection device for USB OTG applications. It includes under voltage and over voltage lockout, over-current, over-temperature, reverse bias and in-rush current protection circuits.
Category Name 3:
Power Management
Product URL 1
14-Channel Configurable Power Management IC | NXP
The PF0100 SMARTMOS Power Management Integrated Circuit (PMIC) provides a highly programmable/configurable architecture, with fully integrated power devices and minimal external components.
Category Name 4:
Memory
Product URL 1
NXH5104UK: 4 Mbit Serial EEPROM | NXP
The NXP NXH5104 is a 4 Mbit serial electrically erasable and programmable read-only memory (EEPROM). It provides byte level and page level serial EEPROM functions, sector level protection and power-down functions.
Category Name 5:
Sensor
Product URL 1
Ultra-low-power, 1.8 V, 1 deg. C accuracy, digital temperature sensor with I2C bus interface | NXP
The PCT2202 is an I2C bus, serial output temperature sensor available in a tiny WLCSP6 package. It requires no external components.
Category Name 6:
RTC
Product URL 1
PCF2123 | NXP
The PCF2123 is a CMOS Real-Time Clock (RTC) and calendar optimized for low power applications. Data is transferred serially via a Serial Peripheral Interface (SPI-bus) with a maximum data rate of 6.25 Mbit/s.
Documentation
i.MX 6 Temperature Sensor Module:  https://www.nxp.com/docs/en/application-note/AN5215.pdf
Tools
Product Link
RD-IMX6Q-SABRE: SABRE Board for Smart Devices Based on the i.MX 6Quad Applications Processors i.MX 6Quad SABRE Development Board | NXP
KITPF0100EPEVBE: Evaluation Kit - MMPF0100, 14 Channel Configurable PMIC EVB- MMPF0100, 14 Channel Configurable PMIC | NXP
OM13512: Demoboard for the SPI-bus RTC PCF2123 Demoboard for the SPI-bus RTC PCF2123 | NXP
NXH5104ADB: NXH5104A Demo Board NXH5104A Demo Board | NXP
OM13257: Universal Temperature Sensor Daughter Card for the Fm+ Development Kit Universal Temperature Sensor Daughter Card for the Fm+ Development Kit | NXP
TJA1100HN: Evaluation Board, TJA1100HN 100BASE-T1 PHY Transceiver TJA1100 Customer Evaluation Board | NXP
Labels (2)
%3CLINGO-SUB%20id%3D%22lingo-sub-1105578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERemote%20Access%20Unit%20Block%20Diagram%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRemote-Access-Unit-Block-Diagram%2Fta-p%2F1105578%23toc-hId-380638960%22%20target%3D%22_blank%22%3EDescription%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRemote-Access-Unit-Block-Diagram%2Fta-p%2F1105578%23toc-hId--1426815503%22%20target%3D%22_blank%22%3EFeatures%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRemote-Access-Unit-Block-Diagram%2Fta-p%2F1105578%23toc-hId-1060697330%22%20target%3D%22_blank%22%3EBlock%20Diagram%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRemote-Access-Unit-Block-Diagram%2Fta-p%2F1105578%23toc-hId--746757133%22%20target%3D%22_blank%22%3EProducts%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRemote-Access-Unit-Block-Diagram%2Fta-p%2F1105578%23toc-hId-1740755700%22%20target%3D%22_blank%22%3EDocumentation%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRemote-Access-Unit-Block-Diagram%2Fta-p%2F1105578%23toc-hId--66698763%22%20target%3D%22_blank%22%3ETools%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FP%3E%0A%3CH1%20id%3D%22toc-hId-380638960%22%20id%3D%22toc-hId-1297818285%22%3EDescription%3C%2FH1%3E%0A%3CBR%20%2F%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3EIndustry%204.0%20applications%20demand%20superior%20performance%20and%20reliable%20communications%20for%20network%20synchronization%2C%20on-time%20data%20delivery%2C%20and%20energy%20efficiency%E2%80%94even%20under%20the%20most%20extreme%20operating%20conditions.%20Current%20manufacturing%20challenges%20require%20flexible%20platforms%20capable%20of%20uniting%20trustworthy%20networking%20protocols%20with%20modern%20and%20reliable%20machine-to-machine%20communications.%3C%2FP%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3EA%20remote%20access%20unit%20works%20as%20an%20interface%20for%20machinery%20that%20can%E2%80%99t%20be%20accessed.%20This%20tool%20displays%20parameters%2C%20measurements%20and%20can%20control%20any%20features%20of%20the%20linked%20machine.%3C%2FP%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3EThis%20remote%20access%20unit%20application%20is%20based%20in%20an%20i.MX%206%20applications%20processor%20that%20can%20be%20programmed%20with%20a%20Linux%20distribution%20and%20Built-in%202G%2F3G%2FGPS%2FGlonass.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH1%20id%3D%22toc-hId--1426815503%22%20id%3D%22toc-hId--509636178%22%3EFeatures%3C%2FH1%3E%0A%3CUL%3E%0A%3CLI%3EGPU%203D%3C%2FLI%3E%0A%3CLI%3EGPU%202D%20(Vector%20Graphics)%3C%2FLI%3E%0A%3CLI%3ECamera%20Interface%3C%2FLI%3E%0A%3CLI%3ECryptographic%20cipher%20engines%3C%2FLI%3E%0A%3CLI%3ETamper%20detection%3C%2FLI%3E%0A%3CLI%3EEthernet%3C%2FLI%3E%0A%3CLI%3EFour%20USB2.0%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CH1%20id%3D%22toc-hId-1060697330%22%20id%3D%22toc-hId-1977876655%22%3EBlock%20Diagram%3C%2FH1%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_8.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F94763i76D7BF6564AC0C66%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_8.png%22%20alt%3D%22pastedImage_8.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_8.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH1%20id%3D%22toc-hId--746757133%22%20id%3D%22toc-hId-170422192%22%3EProducts%3C%2FH1%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20style%3D%22border%3A%200px%20none%20%233d3d3d%3B%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border%3A%201pt%20solid%20windowtext%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ECategory%20Name%201%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20906px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EMPU%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20URL%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20906px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-processors%2Fi.mx-applications-processors%2Fi.mx-6-processors%2Fi.mx-6dual-processors-dual-core-3d-graphics-hd-video-multimedia-arm-cortex-a9-core%3Ai.MX6D%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-processors%2Fi.mx-applications-processors%2Fi.mx-6-processors%2Fi.mx-6dual-processors-dual-core-3d-graphics-hd-video-multimedia-arm-cortex-a9-core%3Ai.MX6D%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX%206Dual%20Applications%20Processors%20%7C%20Dual%20Arm%C2%AE%20Cortex%C2%AE-A9%20%401.2GHz%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20Description%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20906px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EThe%20i.MX%206%20series%20of%20applications%20processors%20combines%20broad%20levels%20of%20integration%20and%20power-efficient%20processing%20capabilities%20all%20the%20way%20up%20to%20bleeding%20edge%203D%20and%202D%20graphics%2C%20as%20well%20as%20high-definition%20video%2C%20to%20provide%20a%20new%20level%20of%20multimedia%20performance%20for%20an%20unbounded%20next-generation%20user%20experience.%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20style%3D%22border%3A%200px%20none%20%233d3d3d%3B%22%3E%0A%3CTBODY%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22border%3A%201pt%20solid%20windowtext%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ECategory%20Name%202%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20905px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ETransceiver%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20URL%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20905px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fcan-transceivers%2Fhigh-speed-can-transceiver-mantis-family%3ATJA1057%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fcan-transceivers%2Fhigh-speed-can-transceiver-mantis-family%3ATJA1057%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ETJA1057%20%7C%20High%20speed%20CAN%20transceiver%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2050px%3B%22%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%20height%3A%2050px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20Description%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20905px%3B%20height%3A%2050px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EThe%20TJA1057%20is%20part%20of%20the%20Mantis%20family%20of%20high-speed%20CAN%20transceivers.%20It%20provides%20an%20interface%20between%20a%20Controller%20Area%20Network%20(CAN)%20protocol%20controller%20and%20the%20physical%20two-wire%20CAN%20bus%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20URL%202%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20905px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fethernet-%2Fautomotive-ethernet-phy-transceivers%2F2nd-generation-ethernet-phy-transceivers-ieee-100base-t1-compliant%3ATJA1101%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fethernet-%2Fautomotive-ethernet-phy-transceivers%2F2nd-generation-ethernet-phy-transceivers-ieee-100base-t1-compliant%3ATJA1101%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ETJA1101%20%7C%202nd%20generation%20PHY%20Transceiver%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20Description%202%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20905px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ETJA1101%20is%20a%20high-performance%20single%20port%2C%20IEEE%20100BASE-T1%20compliant%20Ethernet%20PHY%20Transceiver.%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20URL%203%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20905px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fload-switches%2Flogic-controlled-high-side-power-switch%3ANX5P1100UK%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fload-switches%2Flogic-controlled-high-side-power-switch%3ANX5P1100UK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ELogic%20controlled%20high-side%20power%20switch%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2050px%3B%22%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%20height%3A%2050px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20Description%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20905px%3B%20height%3A%2050px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EThe%20NX5P1100%20is%20an%20advanced%20power%20switch%20and%20ESD-protection%20device%20for%20USB%20OTG%20applications.%20It%20includes%20under%20voltage%20and%20over%20voltage%20lockout%2C%20over-current%2C%20over-temperature%2C%20reverse%20bias%20and%20in-rush%20current%20protection%20circuits.%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20style%3D%22border%3A%200px%20none%20%233d3d3d%3B%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border%3A%201pt%20solid%20windowtext%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ECategory%20Name%203%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20904px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EPower%20Management%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20URL%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20904px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fpmics%2Fpmics-for-i.mx-applications-processors%2F14-channel-configurable-power-management-ic%3AMMPF0100%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fpmics%2Fpmics-for-i.mx-applications-processors%2F14-channel-configurable-power-management-ic%3AMMPF0100%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E14-Channel%20Configurable%20Power%20Management%20IC%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20Description%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20904px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EThe%20PF0100%20SMARTMOS%20Power%20Management%20Integrated%20Circuit%20(PMIC)%20provides%20a%20highly%20programmable%2Fconfigurable%20architecture%2C%20with%20fully%20integrated%20power%20devices%20and%20minimal%20external%20components.%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20style%3D%22border%3A%200px%20none%20%233d3d3d%3B%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border%3A%201pt%20solid%20windowtext%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ECategory%20Name%204%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20903px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EMemory%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20URL%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20903px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fpages%2F4-mbit-serial-spi-eeprom%3ANXH5104UK%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fpages%2F4-mbit-serial-spi-eeprom%3ANXH5104UK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ENXH5104UK%3A%204%20Mbit%20Serial%20EEPROM%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20Description%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20903px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EThe%20NXP%20NXH5104%20is%20a%204%20Mbit%20serial%20electrically%20erasable%20and%20programmable%20read-only%20memory%20(EEPROM).%20It%20provides%20byte%20level%20and%20page%20level%20serial%20EEPROM%20functions%2C%20sector%20level%20protection%20and%20power-down%20functions.%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20style%3D%22border%3A%200px%20none%20%233d3d3d%3B%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border%3A%201pt%20solid%20windowtext%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ECategory%20Name%205%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20903px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ESensor%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20URL%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20903px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Fic-digital-temperature-sensors%2Fultra-low-power-1.8-v-1-deg.-c-accuracy-digital-temperature-sensor-with-ic-bus-interface%3APCT2202UK%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Fic-digital-temperature-sensors%2Fultra-low-power-1.8-v-1-deg.-c-accuracy-digital-temperature-sensor-with-ic-bus-interface%3APCT2202UK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EUltra-low-power%2C%201.8%20V%2C%201%20deg.%20C%20accuracy%2C%20digital%20temperature%20sensor%20with%20I2C%20bus%20interface%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20Description%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20903px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EThe%20PCT2202%20is%20an%20I2C%20bus%2C%20serial%20output%20temperature%20sensor%20available%20in%20a%20tiny%20WLCSP6%20package.%20It%20requires%20no%20external%20components.%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20style%3D%22border%3A%200px%20none%20%233d3d3d%3B%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border%3A%201pt%20solid%20windowtext%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ECategory%20Name%206%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20899px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ERTC%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20URL%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20899px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fperipherals-and-logic%2Fsignal-chain%2Freal-time-clocks%2Frtcs-with-spi%2Fspi-real-time-clock-calendar%3APCF2123%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fperipherals-and-logic%2Fsignal-chain%2Freal-time-clocks%2Frtcs-with-spi%2Fspi-real-time-clock-calendar%3APCF2123%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EPCF2123%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20Description%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20899px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EThe%20PCF2123%20is%20a%20CMOS%20Real-Time%20Clock%20(RTC)%20and%20calendar%20optimized%20for%20low%20power%20applications.%20Data%20is%20transferred%20serially%20via%20a%20Serial%20Peripheral%20Interface%20(SPI-bus)%20with%20a%20maximum%20data%20rate%20of%206.25%20Mbit%2Fs.%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CH1%20id%3D%22toc-hId-1740755700%22%20id%3D%22toc-hId--1637032271%22%3EDocumentation%3C%2FH1%3E%0A%3CP%3Ei.MX%206%20Temperature%20Sensor%20Module%3A%26nbsp%3B%26nbsp%3B%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN5215.pdf%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN5215.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN5215.pdf%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH1%20id%3D%22toc-hId--66698763%22%20id%3D%22toc-hId-850480562%22%3ETools%3C%2FH1%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%3E%0A%3CTR%20style%3D%22background-color%3A%20%2352cc8f%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2047.2774%25%3B%22%3EProduct%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2050.8211%25%3B%22%3ELink%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2047.2774%25%3B%22%3ERD-IMX6Q-SABRE%3A%20SABRE%20Board%20for%20Smart%20Devices%20Based%20on%20the%20i.MX%206Quad%20Applications%20Processors%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2050.8211%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fi.mx-evaluation-and-development-boards%2Fsabre-board-for-smart-devices-based-on-the-i.mx-6quad-applications-processors%3ARD-IMX6Q-SABRE%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fi.mx-evaluation-and-development-boards%2Fsabre-board-for-smart-devices-based-on-the-i.mx-6quad-applications-processors%3ARD-IMX6Q-SABRE%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX%206Quad%20SABRE%20Development%20Board%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2047.2774%25%3B%22%3EKITPF0100EPEVBE%3A%20Evaluation%20Kit%20-%20MMPF0100%2C%2014%20Channel%20Configurable%20PMIC%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2050.8211%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fanalog-toolbox%2Fevaluation-kit-mmpf0100-14-channel-configurable-pmic%3AKITPF0100EPEVBE%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fanalog-toolbox%2Fevaluation-kit-mmpf0100-14-channel-configurable-pmic%3AKITPF0100EPEVBE%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EEVB-%20MMPF0100%2C%2014%20Channel%20Configurable%20PMIC%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2047.2774%25%3B%22%3EOM13512%3A%20Demoboard%20for%20the%20SPI-bus%20RTC%20PCF2123%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2050.8211%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fperipherals-and-logic%2Fsignal-chain%2Freal-time-clocks%2Frtcs-with-spi%2Fdemoboard-for-the-spi-bus-rtc-pcf2123%3AOM13512%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fperipherals-and-logic%2Fsignal-chain%2Freal-time-clocks%2Frtcs-with-spi%2Fdemoboard-for-the-spi-bus-rtc-pcf2123%3AOM13512%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EDemoboard%20for%20the%20SPI-bus%20RTC%20PCF2123%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2047.2774%25%3B%22%3ENXH5104ADB%3A%20NXH5104A%20Demo%20Board%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2050.8211%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fwireless%2Fmiglo%2Fnxh5104a-demo-board%3ANXH5104ADB%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fwireless%2Fmiglo%2Fnxh5104a-demo-board%3ANXH5104ADB%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ENXH5104A%20Demo%20Board%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2047.2774%25%3B%22%3EOM13257%3A%20Universal%20Temperature%20Sensor%20Daughter%20Card%20for%20the%20Fm%2B%20Development%20Kit%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2050.8211%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Fic-digital-temperature-sensors%2Funiversal-temperature-sensor-daughter-card-for-the-fm-plus-development-kit%3AOM13257%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Fic-digital-temperature-sensors%2Funiversal-temperature-sensor-daughter-card-for-the-fm-plus-development-kit%3AOM13257%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EUniversal%20Temperature%20Sensor%20Daughter%20Card%20for%20the%20Fm%2B%20Development%20Kit%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2047.2774%25%3B%22%3ETJA1100HN%3A%20Evaluation%20Board%2C%20TJA1100HN%20100BASE-T1%20PHY%20Transceiver%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2050.8211%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fanalog-toolbox%2Ftja1100hn-evaluation-board-tja1100hn-100base-t1-phy-transceiver%3AOM14500-TJA1100%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fanalog-toolbox%2Ftja1100hn-evaluation-board-tja1100hn-100base-t1-phy-transceiver%3AOM14500-TJA1100%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ETJA1100%20Customer%20Evaluation%20Board%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1105578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EBlock%20Diagrams%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EIndustrial%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎10-20-2020 09:25 AM
Updated by:
