Handwritten Digit Recognition on MNIST dataset using eIQ
About this demo
This demo shows the usage of a Neural Network (NN) applied for handwritten digit recognition, the NN model runs on the i.MX RT1060 MCU. The main idea of the demonstration is to show the i.MX RT capability to manage a graphical user interface while applying a NN model to recognize handwritten numbers to determine whether a password is correct or wrong. The demonstration is tested by setting a 4-digit password to a 4.3" LCD Panel, then the user must enter the correct password to unlock device; when the password is provided, the digits recognized by the NN are displayed on the screen. A 'Clear' button will erase the previous numbers for the user to try a new password to unlock the device.
Technical Introduction and Acknowledgment
The demo is available using two different approaches for the model creation and inference engines: TensorFlow Lite and CMSIS-NN using Caffe Framework.
TensorFlow Lite
The application note AN12603 describes handwritten digit recognition on embedded systems through deep learning. The digit recognition is performed by a TensorFlow Lite model trained with the MINST dataset containing 60,000 handwritten grayscale images and 10,000 testing examples. This application note, deep dives into every step to achieve the application using Tensorflow Lite and build a GUI using Embedded Wizard.
CMSIS-NN using Caffee Framework
The application note AN12781 explores the usage of Deep Neural Networks created in Caffe Framework, this framework allows creating a model and convert it to CMSIS-NN functions to be exported to the i.MX RT platform as source files. The model is also trained for the digit recognition using the MNIST dataset. The document describes the procedure to create, train and deploy the model; in the final step the model is exported a C source files using CMSIS-NN functions and weights that are exported to the i.MX RT1060 project.
Video
(マイビデオを表示)
Hardware setup
Recommended Products
i.MX RT1060 Evaluation Kit | NXP
4.3" LCD Panel RK043FN02H-CT | NXP
Further Information
The NXP® eIQ™ software environment enables the use of ML algorithms on NXP MCUs, i.MX RT crossover MCUs, and i.MX family SoCs. eIQ software includes inference engines, neural network compilers and optimized libraries.
Additionally,  the models can be optimized through techniques like quantization and pruning, AN12781 explores the possibility of optimization by creating a new model using Caffe with a quantization to simplify the floating-point data. By reducing the 32-bit floating-point data to an 8-bit and fixed-point format, the memory allocation got reduced and this resulted in a lower-processing power.
Transfer Learning
Transfer learning gives machine learning models the ability to apply past experience to quickly and more accurately learn to solve new problems. This technique has become very important in deep learning. AN12892 describes how to perform transfer learning in TensorFlow and a use case example, which aims to improve the performance of the application from AN12603.
Useful Links
Links
 AN12603
AN12603 Software
AN12781
AN12781 Software
AN12892
AN12892 Software
eIQ™ for TensorFlow Lite | NXP
Caffe | Deep Learning Framework
Embedded Wizard | Simplify Your GUI Development
What is a Container? | App Containerization | Docker
ラベル(2)
%3CLINGO-SUB%20id%3D%22lingo-sub-1116991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EeIQ%E3%82%92%E7%94%A8%E3%81%84%E3%81%9FMNIST%E3%83%87%E3%83%BC%E3%82%BF%E3%82%BB%E3%83%83%E3%83%88%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E6%89%8B%E6%9B%B8%E3%81%8D%E6%95%B0%E5%AD%97%E8%AA%8D%E8%AD%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FHandwritten-Digit-Recognition-on-MNIST-dataset-using-eIQ%2Fta-p%2F1116991%23toc-hId-1082660749%22%20target%3D%22_blank%22%3E%E3%81%93%E3%81%AE%E3%83%87%E3%83%A2%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FHandwritten-Digit-Recognition-on-MNIST-dataset-using-eIQ%2Fta-p%2F1116991%23toc-hId--724793714%22%20target%3D%22_blank%22%3E%E6%8A%80%E8%A1%93%E7%B4%B9%E4%BB%8B%E3%81%A8%E8%AC%9D%E8%BE%9E%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A75px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FHandwritten-Digit-Recognition-on-MNIST-dataset-using-eIQ%2Fta-p%2F1116991%23toc-hId--34232240%22%20target%3D%22_blank%22%3ETensorFlow%20Lite%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A75px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FHandwritten-Digit-Recognition-on-MNIST-dataset-using-eIQ%2Fta-p%2F1116991%23toc-hId--1841686703%22%20target%3D%22_blank%22%3ECaffee%20Framework%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FCMSIS-NN%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FHandwritten-Digit-Recognition-on-MNIST-dataset-using-eIQ%2Fta-p%2F1116991%23toc-hId--1852189807%22%20target%3D%22_blank%22%3E%E3%83%93%E3%83%87%E3%82%AA%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FHandwritten-Digit-Recognition-on-MNIST-dataset-using-eIQ%2Fta-p%2F1116991%23toc-hId-1315381396%22%20target%3D%22_blank%22%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FHandwritten-Digit-Recognition-on-MNIST-dataset-using-eIQ%2Fta-p%2F1116991%23toc-hId-1995439766%22%20target%3D%22_blank%22%3E%E8%A9%B3%E7%B4%B0%E6%83%85%E5%A0%B1%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FHandwritten-Digit-Recognition-on-MNIST-dataset-using-eIQ%2Fta-p%2F1116991%23toc-hId-1980334657%22%20target%3D%22_blank%22%3E%E8%BB%A2%E7%A7%BB%E5%AD%A6%E7%BF%92%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FHandwritten-Digit-Recognition-on-MNIST-dataset-using-eIQ%2Fta-p%2F1116991%23toc-hId-172880194%22%20target%3D%22_blank%22%3E%E4%BE%BF%E5%88%A9%E3%81%AA%E3%83%AA%E3%83%B3%E3%82%AF%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId-1082660749%22%20id%3D%22toc-hId-2005309913%22%3E%E3%81%93%E3%81%AE%E3%83%87%E3%83%A2%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3C%2FH3%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E3%81%93%E3%81%AE%E3%83%87%E3%83%A2%E3%81%A7%E3%81%AF%E3%80%81%E6%89%8B%E6%9B%B8%E3%81%8D%E3%81%AE%E6%95%B0%E5%AD%97%E8%AA%8D%E8%AD%98%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%83%8B%E3%83%A5%E3%83%BC%E3%83%A9%E3%83%AB%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF(NN)%E3%81%AE%E4%BD%BF%E7%94%A8%E6%B3%95%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81NN%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AF%20%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-microcontrollers%2Fi-mx-rt-crossover-mcus%2Fi-mx-rt1060-crossover-mcu-with-arm-cortex-m7-core%3Ai.MX-RT1060%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-microcontrollers%2Fi-mx-rt-crossover-mcus%2Fi-mx-rt1060-crossover-mcu-with-arm-cortex-m7-core%3Ai.MX-RT1060%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX%20RT1060%20MCU%3C%2FA%3E%E4%B8%8A%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%87%E3%83%A2%E3%81%AE%E4%B8%BB%E3%81%AA%E7%9B%AE%E7%9A%84%E3%81%AF%E3%80%81%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%82%AB%E3%83%AB%E3%83%BB%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E7%AE%A1%E7%90%86%E3%81%99%E3%82%8B%20i.MX%20RT%E6%A9%9F%E8%83%BD%E3%82%92%E7%A4%BA%E3%81%99%E3%81%A8%E3%81%A8%E3%82%82%E3%81%AB%E3%80%81NN%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E6%89%8B%E6%9B%B8%E3%81%8D%E3%81%AE%E6%95%B0%E5%AD%97%E3%82%92%E8%AA%8D%E8%AD%98%E3%81%97%E3%80%81%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%8B%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%92%E5%88%A4%E6%96%AD%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%83%87%E3%83%A2%E3%81%AF%E3%80%81%20%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fi-mx-evaluation-and-development-boards%2F4-3-lcd-panel%3ARK043FN02H-CT%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fi-mx-evaluation-and-development-boards%2F4-3-lcd-panel%3ARK043FN02H-CT%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E4.3%E3%82%A4%E3%83%B3%E3%83%81LCD%E3%83%91%E3%83%8D%E3%83%AB%3C%2FA%3E%20%E3%81%AB4%E6%A1%81%E3%81%AE%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%83%86%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%84%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81NN%E3%81%8C%E8%AA%8D%E8%AD%98%E3%81%97%E3%81%9F%E6%95%B0%E5%AD%97%E3%81%8C%E7%94%BB%E9%9D%A2%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%80%8C%E3%82%AF%E3%83%AA%E3%82%A2%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%81%AF%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%8C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%82%92%E8%A9%A6%E3%81%99%E3%81%9F%E3%82%81%E3%81%AB%E4%BB%A5%E5%89%8D%E3%81%AE%E7%95%AA%E5%8F%B7%E3%82%92%E6%B6%88%E5%8E%BB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId--724793714%22%20id%3D%22toc-hId-197855450%22%3E%3CBR%20%2F%3E%E6%8A%80%E8%A1%93%E7%B4%B9%E4%BB%8B%E3%81%A8%E8%AC%9D%E8%BE%9E%3C%2FH3%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E3%81%93%E3%81%AE%E3%83%87%E3%83%A2%E3%81%AF%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E4%BD%9C%E6%88%90%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%81%A8%E6%8E%A8%E8%AB%96%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%81%AE%202%20%E3%81%A4%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%20(%20%3CSTRONG%3ETensorFlow%20Lite%3C%2FSTRONG%3E%20%E3%81%A8%20Caffe%20Framework%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20%3CSTRONG%3ECMSIS-NN%3C%2FSTRONG%3E%20)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CH4%20style%3D%22text-align%3A%20justify%3B%22%20id%3D%22toc-hId--34232240%22%20id%3D%22toc-hId-888416924%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%22%3ETensorFlow%20Lite%3C%2FSPAN%3E%3C%2FH4%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E3%81%93%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%20%3CA%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12603.pdf%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12603.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN12603%E3%81%A7%E3%81%AF%E3%80%81%3C%2FA%3E%20%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%E3%83%A9%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%AB%E3%82%88%E3%82%8B%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E4%B8%8A%E3%81%AE%E6%89%8B%E6%9B%B8%E3%81%8D%E3%81%AE%E6%95%B0%E5%AD%97%E8%AA%8D%E8%AD%98%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%95%B0%E5%AD%97%E3%81%AE%E8%AA%8D%E8%AD%98%E3%81%AF%E3%80%8160%2C000%20%E6%9E%9A%E3%81%AE%E6%89%8B%E6%9B%B8%E3%81%8D%E3%82%B0%E3%83%AC%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E7%94%BB%E5%83%8F%E3%81%A8%2010%2C000%20%E5%80%8B%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E4%BE%8B%E3%82%92%E5%90%AB%E3%82%80%20MINST%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%BB%E3%83%83%E3%83%88%E3%81%A7%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%9F%20TensorFlow%20Lite%20%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81Tensorflow%20Lite%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%97%E3%80%81%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.embedded-wizard.de%2F%22%20href%3D%22https%3A%2F%2Fwww.embedded-wizard.de%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EEmbedded%20Wizard%3C%2FA%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6GUI%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A9%B3%E3%81%97%E3%81%8F%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CH4%20style%3D%22text-align%3A%20justify%3B%22%20id%3D%22toc-hId--1841686703%22%20id%3D%22toc-hId--919037539%22%3ECaffee%20Framework%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FCMSIS-NN%3C%2FH4%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E3%81%93%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%20%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12781.pdf%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12781.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN12781%3C%2FA%3E%20%E3%81%A7%E3%81%AF%E3%80%81%20%3CA%20class%3D%22jivelink10%22%20title%3D%22https%3A%2F%2Fcaffe.berkeleyvision.org%2F%22%20href%3D%22https%3A%2F%2Fcaffe.berkeleyvision.org%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ECaffe%20Framework%3C%2FA%3E%E3%81%A7%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%E3%83%8B%E3%83%A5%E3%83%BC%E3%83%A9%E3%83%AB%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%E3%82%92%E6%8E%A2%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%93%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%A7%E3%81%AF%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92CMSIS-NN%E9%96%A2%E6%95%B0%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%A6%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%20i.MX%20RT%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AB%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AF%E3%80%81MNIST%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E6%95%B0%E5%AD%97%E8%AA%8D%E8%AD%98%E3%81%AE%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%82%82%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%80%81%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%80%81%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%BE%8C%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A7%E3%81%AF%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AFCMSIS-NN%E9%96%A2%E6%95%B0%E3%81%A8%E3%82%A6%E3%82%A7%E3%82%A4%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6C%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%80%81%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fi-mx-evaluation-and-development-boards%2Fmimxrt1060-evk-i-mx-rt1060-evaluation-kit%3AMIMXRT1060-EVK%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fi-mx-evaluation-and-development-boards%2Fmimxrt1060-evk-i-mx-rt1060-evaluation-kit%3AMIMXRT1060-EVK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX%20RT1060%3C%2FA%3E%E3%81%AB%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%20%3CSPAN%20class%3D%22link-titled%22%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId--1852189807%22%20id%3D%22toc-hId--929540643%22%3E%3CBR%20%2F%3E%E3%83%93%E3%83%87%E3%82%AA%3C%2FH3%3E%0A%3CBR%20%2F%3E%0A%3CH3%20id%3D%22toc-hId-635323026%22%20id%3D%22toc-hId-1557972190%22%3E%3CDIV%20class%3D%22lia-vid-container%20video-embed-center%22%3E%3CDIV%20id%3D%22lia-vid-6185808011001w320h240r469%22%20class%3D%22lia-video-brightcove-player-container%22%3E%3CVIDEO-JS%20data-video-id%3D%226185808011001%22%20data-account%3D%226153537070001%22%20data-player%3D%22default%22%20data-embed%3D%22default%22%20class%3D%22vjs-fluid%22%20controls%3D%22%22%20data-application-id%3D%22%22%20style%3D%22width%3A%20100%25%3B%20height%3A%20100%25%3B%22%3E%3C%2FVIDEO-JS%3E%3C%2FDIV%3E%3CSCRIPT%20src%3D%22https%3A%2F%2Fplayers.brightcove.net%2F6153537070001%2Fdefault_default%2Findex.min.js%22%3E%3C%2FSCRIPT%3E%3CA%20class%3D%22video-embed-link%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fvideo%2Fgallerypage%2Fvideo-id%2F6185808011001%22%20target%3D%22_blank%22%3E(%E3%83%9E%E3%82%A4%E3%83%93%E3%83%87%E3%82%AA%E3%81%A7%E8%A6%96%E8%81%B4)%3C%2FA%3E%3C%2FDIV%3E%3C%2FH3%3E%0A%3CH3%20id%3D%22toc-hId--1172131437%22%20id%3D%22toc-hId--249482273%22%3E%26nbsp%3B%3C%2FH3%3E%0A%3CH3%20id%3D%22toc-hId-1315381396%22%20id%3D%22toc-hId--2056936736%22%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FH3%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2064.4068%25%3B%22%3E%E6%8E%A8%E5%A5%A8%E8%A3%BD%E5%93%81%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2064.4068%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fi-mx-evaluation-and-development-boards%2Fmimxrt1060-evk-i-mx-rt1060-evaluation-kit%3AMIMXRT1060-EVK%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fi-mx-evaluation-and-development-boards%2Fmimxrt1060-evk-i-mx-rt1060-evaluation-kit%3AMIMXRT1060-EVK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX%20RT1060%20%E8%A9%95%E4%BE%A1%E3%82%AD%E3%83%83%E3%83%88%20%7CNXP%E3%81%AE%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2064.4068%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fi-mx-evaluation-and-development-boards%2F4-3-lcd-panel%3ARK043FN02H-CT%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fi-mx-evaluation-and-development-boards%2F4-3-lcd-panel%3ARK043FN02H-CT%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E4.3%E3%82%A4%E3%83%B3%E3%83%81%E6%B6%B2%E6%99%B6%E3%83%91%E3%83%8D%E3%83%AB%20RK043FN02H-CT%20%7CNXP%E3%81%AE%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CH3%20id%3D%22toc-hId--492073067%22%20id%3D%22toc-hId-430576097%22%3E%26nbsp%3B%3C%2FH3%3E%0A%3CH3%20id%3D%22toc-hId-1995439766%22%20id%3D%22toc-hId--1376878366%22%3E%E8%A9%B3%E7%B4%B0%E6%83%85%E5%A0%B1%3C%2FH3%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fsoftware%2Fdevelopment-software%2Feiq-ml-development-environment%3AEIQ%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ENXP%3CSUP%3E%C2%AE%3C%2FSUP%3E%20eIQ%3CSUP%3E%E2%84%A2%3C%2FSUP%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E7%92%B0%E5%A2%83%3C%2FA%3E%E3%81%A7%E3%81%AF%E3%80%81NXP%20MCU%E3%80%81i.MX%20RT%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BCMCU%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%20i.MX%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AASoC%E3%81%A7ML%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82eIQ%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%81%AF%E3%80%81%E6%8E%A8%E8%AB%96%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%80%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%83%A9%E3%83%AB%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%80%81%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E9%87%8F%E5%AD%90%E5%8C%96%E3%82%84%E3%83%97%E3%83%AB%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%AA%E3%81%A9%E3%81%AE%E6%89%8B%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%A7%E3%81%8D%E3%82%8BAN12781%E3%80%81Caffe%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%96%B0%E3%81%97%E3%81%84%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E9%87%8F%E5%AD%90%E5%8C%96%E3%81%97%E3%81%A6%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E7%B0%A1%E7%95%A5%E5%8C%96%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%AE%E5%8F%AF%E8%83%BD%E6%80%A7%E3%82%92%E6%8E%A2%E3%82%8A%E3%81%BE%E3%81%99%E3%80%8232%E3%83%93%E3%83%83%E3%83%88%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E3%83%87%E3%83%BC%E3%82%BF%E3%82%928%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E5%9B%BA%E5%AE%9A%E5%B0%8F%E6%95%B0%E7%82%B9%E5%BD%A2%E5%BC%8F%E3%81%AB%E6%B8%9B%E3%82%89%E3%81%99%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%8C%E5%89%8A%E6%B8%9B%E3%81%95%E3%82%8C%E3%80%81%E5%87%A6%E7%90%86%E8%83%BD%E5%8A%9B%E3%81%8C%E4%BD%8E%E4%B8%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId--507178176%22%20id%3D%22toc-hId-415470988%22%3E%26nbsp%3B%3C%2FH3%3E%0A%3CH3%20id%3D%22toc-hId-1980334657%22%20id%3D%22toc-hId--1391983475%22%3E%E8%BB%A2%E7%A7%BB%E5%AD%A6%E7%BF%92%3C%2FH3%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%22%3E%3CSPAN%3E%E8%BB%A2%E7%A7%BB%E5%AD%A6%E7%BF%92%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E6%A9%9F%E6%A2%B0%E5%AD%A6%E7%BF%92%3C%2FSPAN%3E%3CSPAN%3E%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AF%3C%2FSPAN%3E%20%3CSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%3E%E9%81%8E%E5%8E%BB%E3%81%AE%E7%B5%8C%E9%A8%93%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%3C%2FSPAN%3E%3CSPAN%3E%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E5%AD%A6%E7%BF%92%E3%82%92%3C%2FSPAN%3E%3CSPAN%3E%E8%BF%85%E9%80%9F%E3%81%8B%E3%81%A4%3C%2FSPAN%3E%3CSPAN%3E%E6%AD%A3%E7%A2%BA%E3%81%AB%3C%2FSPAN%3E%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3CSPAN%3E%E3%80%82%E3%81%93%E3%81%AE%E6%89%8B%E6%B3%95%E3%81%AF%E3%80%81%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%E3%83%A9%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%A7%E9%9D%9E%E5%B8%B8%E3%81%AB%E9%87%8D%E8%A6%81%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12892.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN12892%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%20TensorFlow%20%E3%81%A7%E8%BB%A2%E7%A7%BB%E5%AD%A6%E7%BF%92%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%A8%3C%2FSPAN%3E%3CSPAN%3E%E3%80%81AN12603%20%E3%81%8B%E3%82%89%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%82%92%E5%90%91%E4%B8%8A%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%9B%AE%E7%9A%84%E3%81%A8%E3%81%97%E3%81%9F%E3%83%A6%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%AE%E4%BE%8B%3C%2FSPAN%3E%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId-172880194%22%20id%3D%22toc-hId-1095529358%22%3E%E4%BE%BF%E5%88%A9%E3%81%AA%E3%83%AA%E3%83%B3%E3%82%AF%3C%2FH3%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%20height%3A%2025px%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2064.4068%25%3B%20height%3A%2025px%3B%22%3E%E3%83%AA%E3%83%B3%E3%82%AF%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2064.4068%25%3B%20height%3A%2025px%3B%22%3E%0A%3CP%3E%26nbsp%3B%3CA%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12603.pdf%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12603.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN12603%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2064.4068%25%3B%20height%3A%2025px%3B%22%3E%3CA%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN12603SW.zip%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN12603SW.zip%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN12603%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FA%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2064.4068%25%3B%20height%3A%2025px%3B%22%3E%3CA%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12781.pdf%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12781.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN12781%3C%2FA%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2064.4068%25%3B%20height%3A%2025px%3B%22%3E%0A%3CP%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN12781SW.zip%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN12781SW.zip%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN12781%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2064.4068%25%3B%20height%3A%2025px%3B%22%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12892.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN12892%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2064.4068%25%3B%20height%3A%2025px%3B%22%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN12892SW.zip%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN12892%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FA%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2029px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2064.4068%25%3B%20height%3A%2029px%3B%22%3E%3CA%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fsoftware%2Fdevelopment-software%2Feiq-ml-development-environment%2Feiq-for-tensorflow-lite%3AeIQTensorFlowLite%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fsoftware%2Fdevelopment-software%2Feiq-ml-development-environment%2Feiq-for-tensorflow-lite%3AeIQTensorFlowLite%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ETensorFlow%20Lite%20%E3%81%AE%20eIQ%E2%84%A2%20%7CNXP%E3%81%AE%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2064.4068%25%3B%20height%3A%2025px%3B%22%3E%3CA%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20title%3D%22https%3A%2F%2Fcaffe.berkeleyvision.org%2F%22%20href%3D%22https%3A%2F%2Fcaffe.berkeleyvision.org%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%82%AB%E3%83%95%E3%82%A7%20%7C%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%E3%83%A9%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2064.4068%25%3B%20height%3A%2025px%3B%22%3E%3CA%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20title%3D%22https%3A%2F%2Fwww.embedded-wizard.de%2F%22%20href%3D%22https%3A%2F%2Fwww.embedded-wizard.de%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%82%A6%E3%82%A3%E3%82%B6%E3%83%BC%E3%83%89%20%7CGUI%E9%96%8B%E7%99%BA%E3%81%AE%E7%B0%A1%E7%B4%A0%E5%8C%96%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22width%3A%2064.4068%25%3B%20height%3A%2025px%3B%22%3E%3CA%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20title%3D%22https%3A%2F%2Fwww.docker.com%2Fresources%2Fwhat-container%22%20href%3D%22https%3A%2F%2Fwww.docker.com%2Fresources%2Fwhat-container%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%E3%81%A8%E3%81%AF%3F%20%7C%E3%82%A2%E3%83%97%E3%83%AA%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%E5%8C%96%20%7C%E6%B8%AF%E6%B9%BE%E5%8A%B4%E5%83%8D%E8%80%85%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1116991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%A4%E3%83%B3%E3%83%80%E3%82%B9%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%82%B9%E3%83%9E%E3%83%BC%E3%83%88%E3%83%9B%E3%83%BC%E3%83%A0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎10-27-2020 09:48 AM
更新者:
