What will cause this HW error: PH_ERR_CT_OVERUN_ERROR and how to recover
430件の閲覧回数
pkolarov
I am receiving this error when using devkit PNEV7462C and CCID example (project: PN7462AU_ex_phExCcid) to read some ISO7816 smart cards.
Some smart cards work just fine with the example but some return HW fault:  PH_ERR_CT_OVERUN_ERROR  which cannot be recovered from in the example project.
Those smart cards seem to work fine with production CCID card readers so it seems as either a bug in HAL or there needs to be some recovery for the error but not sure what since its always fails in the same place in the communication flow (seems during the first bigger APDU response but nor really sure here).
Any help on how to recover here would be welcomed!
Peter
5 返答(返信)
397件の閲覧回数
EduardoZamora
Hello @pkolarov
Hope you are doing well.
This error should indicate that the Fifo is over run during a communication event. ExCcid demo application from the NFC Reader Library is a demonstration on how to implement CCID functionality, and it handles the USB stack, and both CL and CT interfaces; for these reasons, the software may not be fully optimized as it is intended for test/evaluation purposes.
Eduardo.
364件の閲覧回数
pkolarov
Thanks Eduardo for the response. Yes, I understand it is only a sample code, however the issue seems to be at HAL level (or NXP library)  and not the sample itself. The CL interface seems to not have this issue as its using different HAL, only CT interface has this on an occasion. That is why I have asked about how to recover from such error as I cannot fix this at HAL level (unless you can share HAL sources).
Peter
342件の閲覧回数
EduardoZamora
My apologies, the only HAL sources available are included in ExCcid project > PN7462 > phHal folder.
If the normal operation of your device is stuck, perhaps I could suggest implementing a routine that resets your device when it enters an erroneous state.
Eduardo.
237件の閲覧回数
pkolarov
Unfortunately restart is not an option as it basically fails on regular basis at the same place in communication flow with certain cards. It does not really make any sense ...
417件の閲覧回数
tista3
