Hello guys,
I am trying to read NDEF message from ISO 14443 Type B tag using explore-NFC reader module. But the example programs are only demonstrated for type A tags. Could anyone suggest me any other NFC reader module compatible to raspberry pi which can read NDEF messages from type B tags.
Thank you in advance.
Please refer to AN1425 in which they provide guidance on antenna and RF amplifier design, as you mentioned in the case, it is for devices such as PN5xx and MFRC52x for which the design is the same.
AN1425:
http://www.nxp.com/docs/en/application-note/AN1425_AN166510.zip
Ivan.
