PN7150 emc filter desing without balun
1,424 次查看
alikarakaş
How can i desing pn7150 emc filter with triax coax? Maximum length for triax cable 20cm. Can ve desing without balun .
4 回复数
1,308 次查看
weidong_sun
Dear ali ,
   See suggestions below, please!
1. Design your matching circuit and EMC circuit according to the 50 ohm antenna solution.
2. Reserve RXN for RX balun
In this way, the signal can be received either single-ended or differential.
Solutions for 50OHM single-ended solution will sent to your email. Pay attention to checking it, please!
Have a nice day!
BR,
NXP TIC Weidong
1,308 次查看
alikarakaş
Thank is for your reply. But im connecting tvss line to gnd directly. İs correct for short range antenna ? .
iPhone’umdan gönderildi
Wigros Sun <admin@community.nxp.com<mailto:admin@community.nxp.com>> şunları yazdı (29 Nis 2019 04:30):
NXP Community <https://community.freescale.com/resources/statics/1000/35400-NXP-Community-Email-banner-600x75.jpg>
You have been mentioned
by Wigros Sun<https://community.nxp.com/people/weidong.sun?et=notification.mention> in Re: PN7150 emc filter desing without balun in NXP Community - View Wigros Sun's reference to you<https://community.nxp.com/message/1144808?commentID=1144808&et=notification.mention#comment-1144808>
1,308 次查看
weidong_sun
Dear ali,
   >> But im connecting tvss line to gnd directly. İs correct for short range antenna ?
VSS(TX) pin should be connected to GND, so you are right.
[comment)
  VSS(TX) on PN7150 is TVSS.
Have a nice day!
NXP TIC Weidong Sun
1,197 次查看
erichwolf
Hello Weidong Sun,
please can you post the single ended Antena design in the forum or send it by email?
Thank you
