PN5180 BUSY line still LOW
701 次查看
LiKe
Dear Sir
I test the PN5180 reader IC, I have a question, the PN5180 busy line still to LOW.
The PN5180 write Timer0_reload register data can not BUSY line change to High.
I read the Timer0_reload register
SPI_CS=0;
(void)SPI_send(0x04);
(void)SPI_send(TIMER0_RELOAD);
SPI_CS=1;
delay_ms(100);
SPI_CS=0;
result[0]=SPI_send(0x00);
result[1]=SPI_send(0x00);
result[2]=SPI_send(0x00);
result[3]=SPI_send(0x00);
SPI_CS=1;
the result is right.
I trace the BUSY line by Oscilloscope, the BUSY line to LOW level
but I trace the PN5180 DEMO KIT. The BUSY line can from LOW to High.
Where is the problem?
634 次查看
Kan_Li
Hi Li Ke,
Looks like you toggle the CS line during data exchange. Please kindly refer to the following for details.
Hope that helps,
Kan
