NTAG 424 AuthenticateEV2First RndA not matching
492件の閲覧回数
shaghayeghnz
I am currently developing an application using Flutter to write to an NTAG424 DNA NFC tag; however, I am encountering some issues with AuthenticateEV2First. I get the correct response 9100h but my RndA is not matching with the RndA that I generated.
for instance my generated RndA is 13c5db8a5930439fc3def9a4C675360f. The D(K0 , TI || RndA´ || PDcap2 || PCDcap2) is d8e5fa458b297bedbdc3f3d3d81a09b4746b8598fbaf31afd8afc24623eb2e2. As you can see the RndA' does not match with the one I generated.
p.s. My decryption method works correctly with the examples in https://www.nxp.com/docs/en/application-note/AN12196.pdf
Best regards, Shaghayegh.
タグ(1)
453件の閲覧回数
KellyLi
Hello @shaghayeghnz
Please try the following steps:
Step 1: Field On + RF Reset + Activate Idle + RATS+PPS
Step 2: Originality signature verification
Step 3: ISO SELECT NDEF Application
Step 4: Get File Settings
Step 5: GetVersion
Step 6: AuthticateEV2First ( key store by key 0 = 00000000000000000000000000000000)
kelly
