How to use NFC component pn 7120 with Intel Edison ?
2,288 次查看
bryantrilck
Hi all,
I am working on Intel Edison with Yocto and kernel 3.10 and I have to use NFC component NXP pn7120.
The guide provided by NXP about Linux Software Stack Integration presents only ARM architecture. So how could I do to use NXP pn7120 for x86 architecture and Yocto? Currently I already made the recipe and compile the driver for the target. But I do not know how to modify the device tree or platform data. Could you please tell me how I could do?
Bryan
1,706 次查看
mihaipop11
Hi Bryan, i myself am working on the same very thing but i'm missing the yocto recipe, could you provide that for me?
I have integrated the driver in the kernel via device tree. These are the steps:
Copy the Qualcomm dts file from this folder into linux-2.6-imx/arch/arm/boot/dts
Copy the Qualcomm driver sources from this folder into linux-2.6-imx/drivers/net/ethernet
Add path to the new driver into kernel by modifying the Makefile and Kconfig file from the ethernet folder like this:
Add at the bottom of the Kconfig file: source "drivers/net/ethernet/qualcomm/Kconfig"
Add at the bottom of the Makefile file: obj-$(CONFIG_NET_VENDOR_QUALCOMM) += qualcomm/
and the dts file should look like this:
* Qualcomm qca7000
/dts-v1/;
  compatible = "qcom,qca7000";
  ssp2: spi@80014000 {
        #address-cells = <1>;
        #size-cells = <0>;
        compatible = "fsl,imx6-spi";
        pinctrl-names = "default";
        pinctrl-0 = <&spi2_pins_a>;
        status = "okay";
        qca7000: ethernet@0 {
                compatible = "qca,qca7000";
                reg = <0x0>;  /* CE 0 */
                interrupt-parent = <&gpio3>;      /* GPIO Bank 3 */
                interrupts = <25 0x1>;            /* Index: 25, rising edge */
                spi-cpha;                         /* SPI mode: CPHA=1 */
                spi-cpol;                         /* SPI mode: CPOL=1 */
                spi-max-frequency = <8000000>;    /* freq: 8 MHz */
