Hello everyone, according to the CLRC663 datasheet's page 65, address 00h the 7th bit is standby and 6th one is modemoff bit but in the nfc reader library's Rc663_Reg.h, the standby bit is 0x80U and i can't find the modemoff bit in the header, can any one help?
Solved! Go to Solution.
Yes, you are right. There is no MACRO for Modemoff bit configuration, but you can call API function (
