Stall problem
Stall problem
1,653件の閲覧回数
abderrahimjamao
Hello everyone,
I have a problem when I try to control my motor in sensored mode ( it works in sensorless mode without problem).
as soon as he enters the run state indicates a stall fault. what does it mean this error?
regards,
2 返答(返信)
1,567件の閲覧回数
Alexis_A
Hello abderrahimjamaoui@gmail.com,
In the application code to enable the sensor mode, you need to change the #define HALL_SENSOR to 1 so the FTM2 is enabled. After this change still the motor stalls?
Best Regards.
Alexis Andalon
1,567件の閲覧回数
abderrahimjamao
Hi Alexis Andalon,
Yes, I already change the HALL_SENSOR to 1 but the motor stalls.
Abderrahim jamaoui
