Write register block not showing PWM registers
2,258 次查看
kabraham_abin
The PWM registers are not showing up in write register block for imxrt1024 processor project. its always showing the registers associated with ADC's. Am I doing something wrong? how can I fix it? I cant find an example for write/read register block as well for these processors. please refer the attached image.
2,239 次查看
stefancinipeanu
Hello, @kabraham_abin
Indeed it looks like a bug on our side, so I have been investigated this issue and I fixed the problem.
As a quick workaround, I am going to attach a zip where you will find 2 files. You just have to copy these 2 files into the following directory: {toolbox_path}\NXP_MBDToolbox_IMXRT1xxx\mbdtbx_imxrt\+mbd_imxrt\+reg
It should work and you should see the PWM registers inside the registers blocks.
Let me know if this works.
Stefan.
2,240 次查看
stefancinipeanu
Stefan.
