MBDT: VCOM on iMXRT
MBDT: VCOM on iMXRT
343件の閲覧回数
Sam_ECU
Contributor V
Hello @stefancinipeanu
I'd like to have a VCOM on USB1 and have been following your example below:
https://community.nxp.com/t5/Model-Based-Design-Toolbox-MBDT/iMXRT-Model-won-t-solve-when-activating...
I take the SDK-Example in MCUXpresso "evkmimxrt1060_dev_cdc_vcom_bm" and copy the files into my Matlab Config folder:
I define the directories as:
And the source files as:
(I also tried:
Sam_ECU_2-1716117870768.png)
But the model builds with errors:
How best to resolve?
I also found capabilities in MCUConfig:
But it generates the same errors:
What is the best way to have a VCOM using software from MBDT?
Sam
2 返答(返信)
154件の閲覧回数
stefancinipeanu
Hello @Sam_ECU,
The reason why you have the error regarding the definition of main function twice is because of the virtual_com.c file from the evkmimxrt1060_dev_cdc_vcom_bm MCUXpresso example. That file contains the main function for that particular application and there will a conflict with the main function defined in the Simulink generated code from ert_main.c file.
Try not to add those source files virtual_com.c and virtual_com.h in Simulink project.
Regards!
Stefan.
206件の閲覧回数
Sam_ECU
Contributor V
Is it possible to receive help with the issue?
