how to implement IP filtering in FRDMk64
sudhakarp
Contributor V
hi,
     i want to receive data from particular IP only. so i want to do IP filtering. but i dnt know how to implement that one.
i am using kds2.0 IDE
thanks and regards,
sudhakar p
Luis_Garabo
You should be able to do that by using the recvfrom() function. Only datagrams from that source will be received if a remote endpoint has been specified
with connect().
I hope this helps you.
Garabo
Luis_Garabo
with connect().
Garabo
