I am using Code warrior v10.2 and MQX of v4.0.
I am working on a project in which I need to use MQX message queue.
In my project I have two task.
For example.,
One task will monitor the switches of 5 fan, and send the output with detail like fan number with on/off of switch to other task using message.
Other task will response to message and process on it.
But what I want to do is for example if on a one time say fan 1 is ON then it will send a message to other task, but on a same if say fan 2 is off then message of fan number 2 with detail off should be in queue.
Please Note that I have learnt the demo of MQX msg queue example but cant understand anything.
How I come to know that my message is in a queue.???
I have not worked on message queue ever.
Please help with demo code.....
Hi Utsavi Kalpesh Bharuchwala,
Please check the lwsgq example code, this is located at the below path: C:\Freescale\Freescale_MQX_4_0\mqx\examples\lwmsgq
There are two messages queqes One for the server and another for the client. Take a look to that example. I hope that helps you.
Sol
Hi Sol,
Thnx for Reply.
I will try this.
