Time base for MQX (Lite)
1,238件の閲覧回数
ky3orr
Hello all MQX (Lite) users,
I want to implement simple IoT gateway and I want to try doing it with MQX Lite - if possible (small resources in MKL05).
My requirement is to have gateway's oscillator synchronized in frequency to external frequency standard.
What I want to do is to have one task designated for synchronization, and other that is somehow scheduling RF TDMA data exchange with sensors.
I am curious how to setup a timebaseto have resolution of 1[us] while using MQX.
Is it something outside MQX and I need to do it with timers, or there is a way for setting it in OS component?
I am using KDS 2.0.0 and PE.
Thanks for any hints.
タグ(2)
1,166件の閲覧回数
soledad
Hello Grzegorz Kaczmarek,
You can modify the system timer according your needs.
Please check the below images for reference.
Sol
