Hello everybody. I have a question today. I am using LWGPIO pins in an application, and I want to setup the features of pulldown (or up) in some pins configured as inputs. I found the LWGPIO_ATTR_PULL_UP macro, but I don't know the function to applie that feature. MQXIOUG do not mention this. How can I do this?
I'm using a MCU K60N512 and MQX 3.8.1.
Thanks you all.
Kind regards.
解決済! 解決策の投稿を見る。
Hello gsanches,
we added it into documentation, should be mention in our last release (4.0.1), here's the function for setting attributes, you can find it inside lwpgio code files (like lwgpio_kgpio).
boolean lwgpio_set_attribute
/* Pin handle to get function from */
LWGPIO_STRUCT_PTR handle,
/* PORT attribute */
uint_32 attribute_id,
/* Attribute value */
uint_32 value
/* the body is not copied */
c0170
Hello gsanches,
uint_32 value
c0170
Thanks for your help, I look in the code and I found it.
Kind regards.
