RTCS Watchdog Interference
1,117 次查看
christian_fisch
We encountered a problem on a K60F120M using MQX 4.2.0.2 that seems mainly related to the RTCS module.
Namely when the RTCS module is activated and with a watchdog set to 1 second the system restarts/resets about once a day.
Used modules:
bsp, psp, rtcs and shell.
Configuration for RTCS:
    _RTCSTASK_priority = 7;
    _RTCSTASK_stacksize = 10000;
    _RTCSPCB_init = 4;
    _RTCSPCB_grow = 2;
    _RTCSPCB_max = 10;
    _RTCS_msgpool_init = 4;
    _RTCS_msgpool_grow = 2;
    _RTCS_msgpool_max  = 10;
    _RTCS_socket_part_init = 4;
    _RTCS_socket_part_grow = 2;
    _RTCS_socket_part_max  = 10;
The main task which handles the watchdog has a priortity of 15, furthermore this problem persisted after we temporarly removed all code expect initialization of RTCS and watchdog handling.
863 次查看
christian_fisch
Ok the problem is solved, traced down to refreshing the hardware watchdog without interrupts disabled.
863 次查看
danielchen
Hi Christian
Do you use the MQX software watchdog?
I did a quick check with a demo, combined the watchdog and RTCS,  not found this issue. Could you please let me know how to reproduce your issue on my side?
You also can submit a support requests on NXP website if this issue is important and need fast response.
864 次查看
christian_fisch
863 次查看
danielchen
Thank your for your sharing.
