RTCS TCP/IP
RTCS TCP/IP
630件の閲覧回数
wyao75
Hi all,
I use K60 and MQX 4.1
I'd like to use socket receive TCP/IP packet every 100ms.
computer as server (device A)and k60 as client(device B).
Now K60 can receive data every 100ms .
My question is if device A disconnect and maybe 2mins later it reconnect, but the k60 can't receive data. I try to check the connection state if connection fail it will reconnect, but still not work.
  socket_init();
   uint16_t rlen=sizeof(raddr);
   i=connect(sock_list[0],(struct sockaddr *)&raddr,rlen);
   while(1)
     k=RTCS_selectall(100);
     if (i!= RTCS_OK)
       shutdown(sock_list[0],FLAG_ABORT_CONNECTION);
       socket_init();
     recv(sock_list[0],buffer_tcp,30,0);
3 返答(返信)
399件の閲覧回数
Carlos_Musich
Hi!
You can use the following instruction to check the link status: result = ipcfg_get_link_active(BSP_DEFAULT_ENET_DEVICE);
Then shutdown socket and don't reconnect until link is up again: while(!ipcfg_get_link_active(BSP_DEFAULT_ENET_DEVICE)) {};
Carlos
399件の閲覧回数
wyao75
HI
I want to know how to check the state of TCP/IP connection rather than the state of Ethernet link.
I use computer as server and k60 as client .
In TCP/IP protocol, computer(server) should listen first and then k60 (client) connect it.
I want to know if k60 connect first and the computer listen after 2 min. k60 how to reconnect?
399件の閲覧回数
Carlos_Musich
You can use Connection Timeout option.
To set this option you need function setsockopt() and the option parameter is OPT_CONNECT_TIMEOUT.
You can find it documented in MQX_RTCS_User_Guide.pdf. It is located in installation path:
C:\Freescale\Freescale_MQX_4_2\doc\rtcs
Carlos
