Hi, I'm new on MQX and making a test, I made a project with two tasks, on a KL25Z - Arm M0 Freedom Board. The first and the second task only blink a LED.
Red for Task 1 and Blue for task 2, using a simple delay routine.
These two tasks only run at a first time and do not repeat.
I was wainting Task1, Task 2 and Task 1... again and repeat it forever.
I made many changes, but nothing change this ?
If I make only one task, it repeat, but do why with more than one do not?
I use codewarrior 10.4.
Original Attachment has been moved to: Exercicio2.rar.zip
Solved! Go to Solution.
hi
in the task whatever you want to must be in a while(1) loop.
// task 1 while 1 loop
while(1) {
counter++;
_time_delay_ticks(50);
/* Write your code here ... */
// task 2 while 1 loop
while(1) {
counter++;
RED_NegVal(NULL);
_time_delay_ticks(250);
Note: Lite only support FIFO scheduling , we are using the _time_delay_ticks to block the task.
In this case taks 1 and task2 will called again and again and they will be time delay block for the number of ticks mentioned in the API called for.
Hope this helps
hi
while(1) {
counter++;
while(1) {
counter++;
RED_NegVal(NULL);
Hope this helps
