MQX 4.0 ADC demo does not work on KWIKSTIK
926件の閲覧回数
anguel
Contributor V
Hi!
The ADC demo from MQX 4.0 runs fine in CW 10.3 for the TWR-K70 board. But when I run the demo with KWIKSTIK I get the following output in the CW console window (note: I have ommited some of the many blank lines inbetween):
-------------- Begin ADC example --------------
Opening ADC device ...done
Opening channel #1 ...done, prepared to start by trigger
Opening channel #2 ...done, one sequence started automatically
Triggering channel #1...triggered!
               ADC ch 2: 28819
Pausing channel #1...stopped!
Resuming channel #1...resumed!
Looks like for some reason the read() does not get the result...
Thanks in advance for any help!
Anguel
タグ(5)
4 返答(返信)
542件の閲覧回数
c0170
Senior Contributor III
Hello anguel,
I have tested adc demo and had same result as you reported.
I suspected that it was going to be a problem with semihosting. Thus I disabled it (IODEBUG) and redirected output to another serial module, stepped it through the code, read was returning values. Can you test it with IODEBUG disabled?
c0170
542件の閲覧回数
anguel
Contributor V
Martin,
Thank you for the feedback. Am I correct that when I disable the IODEBUG there is no way to see printf() output? Where do you exactly see the read in ADC values?
Anguel
542件の閲覧回数
anguel
Contributor V
I now redirected output to TWR-SER RS232 and the ADC demo reads in values (at least until I halt the program with the debugger).
Now I tried to set the first adc0 channel from ADC0_SOURCE_ADPM0 to ADC0_SOURCE_AD10 which should be the microphone input on the kwikstik. The problem is that I always read the same value (approx 32000) even if I make some noise. What could be the reason?
BTW: The SD CARD demo also does not work with IODEBUG enabled on the KWIKSTIK. There seem to be some serious problems with the onboard J-Link debugger.
Anguel
542件の閲覧回数
c0170
Hello anguel,
I haven't tested the microphone with ADC. I will have to look into this, but I am currently busy with one release. One thing I have not mentioned, there's file init_iodebug.c where is defined IODEBUG init structure.
const IODEBUG_INIT_STRUCT _bsp_iodebug_init = {
    IODEBUG_MODE_SEMIHOST,  /* Driver mode */
    127,                    /* Length of buffered data */
    '\n'                    /* Default flush character */
Have you tried to tweak at least length of buffered data? If you set it to 0, no buffer will be used.
I reported problems with IODEBUG and adc demo (potentionally with other drivers, I'll have a chat with IODEBUG developer who is currently away), this will be checked.
c0170
