Hi !
My question is simple but i'm really lost ! I use MQX for the first time with CW. I try to build a library but ...
I read this AN ( http://www.freescale.com/files/soft_dev_tools/doc/support_info/FSL_MQX_Getting_Started.pdf )but my english is poor.
If someone can help me... I just want to know how to use library with MQW and how to build it
I ' m looking forward to your reply
Solved! Go to Solution.
Please check the video attached, this shows how build the MQX libraries for the TWR-K60F120. The steps are the same for others boards.
I hope this helps :smileywink:
Soledad
thank you to answering fast !
