Enable lightweight messages
1,934 次查看
intevac_coder
How does one enable lightweight messages in a fresh project?  I am using:
CW 10.1
MQX 3.7
Kinetis K40 tower kit
I have loaded in the bsp_twrk40x256 and the lwmsgq_twrk40x256 projects and messaging works fine.  However, when I create a new project and try to use messages, the compiler throws errors when  including <lwmsgq.h>.
What files/projects have to be modified to include messaging (and other optional components)?  The user manual tells that the bsp needs to be modified but it doesn't tell what or how to make the modifications.
Thanks!
1,690 次查看
DavidS
Hi Intevac_coder,
Would you please post your new project?
"lwmsgq" is enabled by default so you shouldn't have to have changed anything in the new project.
David
1,691 次查看
DavidS
Hi Intevac_coder,
David
1,690 次查看
intevac_coder
David,
Thank you for the response.  I did find that lightweight messages worked after I added mqx.h and bsp.h in my task header.
#include <mqx.h>
#include <bsp.h>
#include <lwmsgq.h>
Otherwise the compiler threw errors.
Thanks!
