I have the same question, too bad no one has responded to you.
I am working with a team that has been able to get three pwm's working (tpm1ch0, tpm1ch1, and tpm1ch2). We did this by going through processor expert and there seems to be no driver to do so using MQX. MQX is necessary for our project because we require socket communication with a pc application. Could anyone please explain why this is?
We have been unsuccessful at setting the registers manually, because functions such as "setReg8" are undefined outside the scope of processor expert.
Hello Sr.
I'm having problems when I try to use Processor Expert or Device Initialization with MQX.
There are defines and configurations conflicts.
May you post a example how to generate this PWM on MCF51CN128?
Only few lines.
Thanks.
best regards
Universidade Estadual de Campinas - Brasil
