If you are using MQX 3.7 and have failures when trying to start RTCS or an RTCS server (Telnet, HTTP, SNMP, ...) : RTCS_create(), TELNETSRV_init(), httpd_server_run(), SNMP_init(), ... returning a failed status.
Also if you use an older release of MQX but have unexpected application crashes when using RTCS
Maybe you are concerned (like me) by the problem decribed in the following post
