BSP Cloning Wizard issue generating projects
1,343件の閲覧回数
albertopr
I tried cloning a BSP and I keep always receiving console error messages when the application tries to Generate MQX Projects (so no proper cloning done).
The error messages starts with:
Generating: BSP for cw10gcc
Can't open nul: No such file or directory
and always finishes with:
C:\Freescale\Freescale_MQX_4_1\tools\generator\..\CodeWarriorNPW\twrk60bspClone_32.reg (El sistema no puede encontrar la ruta especificada)
a translation for last part of the error message could be something like (System cannot find specified path).
I have tried reinstalling all the components but the behaviour is exactly the same.
My system runs MQX 4.1 with CW 10.5 on a Windows 7 machine with Java 7.
The same software installed and running on a Win XP computer works fine.
Does anyone has an idea about why is it happening and a way to fix it?
Alberto.
タグ(2)
7 返答(返信)
817件の閲覧回数
soledad
Hello Alberto,
It is possible that something in your installation is wrong, could you try the below steps??
  1. uninstall MQX
  2. erase manually the MQX folder
  3. install again MQX
  4. follow the video attached
I hope this helps
Saludos
Sol
817件の閲覧回数
albertopr
Thanks for your reply Soledad.
I followed carefully those steps but the problem still stays there.
I had tried before deleting all Freescale folders and I even tried to find a wrong windows register, but I didn't succeed fixing the problem.
The cloning application keeps failing in building all mqx libraries (/build) and other folders (like examples folders)
It seems like if something went wrong during the first installation and it stays there no matter what...
817件の閲覧回数
hengguangyang
I also encount the same issue and don't know how to slove it.
I'm using the newest MQX 4.1.1 with CW 10.6 on a  Win7 machine.
Help!!!!!!!!!!!!!!!!!!!!!!!!!!!:smileysad:
817件の閲覧回数
albertopr
Hi Yang,
As far as I know the problem was not fixed, reinstalling CW or MQX did not work for me.
My "solution" was to use another system or reinstall from 0 the OS  if I wanted to use BSP Clone or another tool like mktfs.
Alberto
817件の閲覧回数
Rename file globals.yml to globals_full.yml fix it.
Refer to
MQX 4.1.1 BSP Cloning Wizard bug and fix (globals_full.yml not found)
Alice.
817件の閲覧回数
hengguangyang
Hi  Alberto,
I have solved the problem by copied globals.yml to globals_full.yml  in path \Freescale\Freescale_MQX_4_1\tools\generator\records\mqx_records.
I don't know why but it acting. Hope it useful for you.
Hengguang
817件の閲覧回数
Hi Yang,
If your problem haven't solved ,you'd better ask a new discussion in  the community ,because this discussion's time is far back and is Assumed Answered ,  the discussion is see at  very small  probability.
Alice
