Hi all,
I'm using a custom board based on the tower TWR-K60F120M running MQX 4.1.
I'm running out of ram, so I'm very keen to add more RAM to the system.
Can anybody tell me if there is an application note on that issue? If not, how Can I implement this, and which is the type of RAM I should use?
Óscar.
解決済! 解決策の投稿を見る。
Hi Oscar,
Attached you can find a simple example in CW10.5 and MQX4.1 (will work in CW10.6 also). Please note that you must enable in user_config.h the macros mentioned in AN4393 and rebuild MQX libraries.
Carlos
Hi Carlos,
Many thanks for your help!
Best regards.
Óscar.
Hi Oscar,
I beleive you will find this appnote interesting:
Garabo
Hi Garabo,
This is very interesting.
Many thanks for your help.
Óscar
