intrinsic_function
intrinsic_function
Jamber_H
Hi, what's intrinsic_function meaning in flow code?
extern void __mtdcrconst unsigned int,  int__attribute__((intrinsic_function(20900"mtdcr") ));
extern void __mtsprconst unsigned int,  int__attribute__((intrinsic_function(20904"mtspr") ));
extern int __mfsprconst unsigned int__attribute__((intrinsic_function(20164"mfspr") ));
Jamber
davidtosenovjan
Hi, where this definitions are taken from?
Jamber_H
Hi, David
It's source code of an OS used for MPC5744
Best Regsrds
Jamber
davidtosenovjan
OK, but it is not a syntax use with S32 Design Studio or some of its component? Or is it?
Jamber_H
The compiler is WindRiver, and IDE is S32DS.
davidtosenovjan
I would apparently forward you to WindRiver support
https://www.windriver.com/support/index.html
because this question is specifically related to directives' syntax of Diab compiler.
