#include "netifcfg.h" file not found error in MPC5748G: ENET_PING example.
1,397 次查看
tejo2one
I am working on NXP Gateway board which uses MPC5748G, I need to setup Ethernet communication and checking example codes. ENET_PING : found this example code but it doesnot build. Is there any example code using ethernet interface which works using MPC5748G.
Thank you in advance,
Tejo
10 回复数
1,370 次查看
tejo2one
Thanks for the response Lukas.
I apologize for mistake, I am using example "lwip_mpc5748g" not ENET_PING.
1,364 次查看
lukaszadrapa
Exactly the same is working also for lwip example. Can you find the file in S32DS folder? Isn't the installation corrupted?
Lukas
1,358 次查看
tejo2one
I uninstalled and reinstalled S32DS., still same issue.
Can you share your code ?
1,362 次查看
tejo2one
Lucas, I could not find this file.
For my reference what is the S32DS version you're using?
1,310 次查看
lukaszadrapa
Hi @tejo2one
I used S32DS 2.1 and SDK 3.0.3.
I just found out that the file is not present in the S32DS installation folder but it's generated by processor expert, so I can see it in my project.
I will attach my project here, you can try to import it.
Lukas
1,074 次查看
tejo2one
Hello @lukaszadrapa ,
              Thanks for your code. I tried loading it in as a local project and when I give generate code command "netifcfg.c and netifcfg.h" are removed by tool.
               I felt my tool was corrupted so reinstalled S32DS again but same problem still exists.
Is there any link where I can download whole setup locally and install it? please support me its already taken lot of time.
 Thanks in advance.
Tejo
1,062 次查看
lukaszadrapa
Hi @tejo2one
If you go to:
Help -> S32DS Extensions and Updates
and
Help -> About S32 Design Studio... -> Installation Details
... could you see if all these packages are installed? That's my setup which works:
There's no way to install this as a one single package.
Lukas
1,284 次查看
tejo2one
Hello Lukas,
Thanks for reply and code. I tried flashing your code but its stuck in HSM_Init during SSL_Init.
Is HSM firmware required to use TCPIP stack ?
Thanks & best regards,
Tejo
1,277 次查看
lukaszadrapa
Please take a look at this thread:
https://community.nxp.com/t5/MPC5xxx/WolfSSL-on-MPC5748G-devkit/m-p/1460985
And also this one - it is possible to use SW implementation only:
https://community.nxp.com/t5/S32-SDK/using-wolfSSL-library-on-MPC5748G-board-with-out-HSM-firmware/m...
Lukas
1,375 次查看
lukaszadrapa
Hi @tejo2one
I can see no problem on my side. What I did:
File -> New -> S32DS Project from Example
Then I selected mentioned enet_ping example for MPC5748G.
Now the key point - it is necessary to generate the code by this:
Or select in main menu: Project -> Generate Processor Expert Code.
Then you should be able to build the project.
Lukas
