how to connect 3 boards for flexray test
912件の閲覧回数
boyoungmun
I would like to set the test environment using 3 MPC5646C boards for verify flexray that has 3 nodes.
Is it possible? If possible, I wonder how to connect 3 boards.
3 返答(返信)
757件の閲覧回数
lukaszadrapa
there are several possible bus topologies. You can see that, for example, here:
FlexRay - Topology | Cypress Semiconductor
Or you can read directly the physical layer spec:
http://tge.cmaisonneuve.qc.ca/barbaud/R%C3%A9f%C3%A9rences%20techniques/Protocoles%20%C3%A0%20tranch...
Lukas
757件の閲覧回数
boyoungmun
Hi Lukas,
If I connect 3 boards using “active star coupler”, is additional evaluation board that mounted active star (e.g TJA1080) needed?
If yes, is it possible to use XPC5646C as active star? Does NXP have the active star board?
757件の閲覧回数
lukaszadrapa
we do not have such board. The easiest way is to use passive star bus topology - you don't need additional HW.
Lukas
