flexcan mpc5777c ON MPC-5777CDEVB
chinna_polukant
in mpc5777c flexcan on mpc5777c_DEVB the iflag is not raising after setting transmission to active .can you check this problem,i attached the program file.
PetrS
be sure connected CAN transceiver is active. See more in https://community.nxp.com/t5/MPC5xxx/MPC5777C-DEVB-CAN-settings-and-S32-CAN-Example/m-p/1000162
BR, Petr
