Variable-Length Encoding (VLE) register rules
Bloodhound
Hi All,
I've been working on a VLE project (written in asm) and I am running in to an annoying issue with certain registers not able to perform tasks.
For example, a simple compare command...
se_cmp  r29,r26  << That is ok
se_cmp  r29,r10  << That creates an error 'Invalid register specified".
I have the VLE reference manual but I cannot find where it discusses what combination of registers are valid to use in situations like this.
Does anyone have any pointers?
Thanks.
Bloodhound
Ok thanks Lukas.
lukaszadrapa
copied from http://www.freescale.com/files/32bit/doc/ref_manual/VLEPEM.pdf , page 23:
"VLE instructions use GPRs and SPRs with the following limitations:
• Most VLE instructions using 16-bit formats are limited to addressing GPR0–GPR7 and
GPR24–GPR31. Move instructions are provided to transfer register contents between these
registers and GPR8–GPR23.
• VLE compare and bit test instructions using the 16-bit formats implicitly set their results in CR0."
That's because there are only 4 bits to specify a GPR in VLE instruction.
Lukas
